Disable all diagram block
Assuming this VI is called by Another VI, just Place that VI-call in a disable structure. 🙂
If this is the only VI, make a wrapper.
To test your new functionality, make a new VI that's in the Enable case.
Qestit Systems
Certified-LabVIEW-Developer
Message 11 of 12
(385 Views)
@crossrulz wrote:
@Alvaro.S wrote:
I would like to diseble the complete block diagram. Because  would like to test an aditional functionality in the same VI. Test it separately and when I will have tested it then enable the other functionalities.
This isn't a LabVIEW issue.  It is a Source Code Control (SCC) issue.  This is why SCC, such as SVN and GIT, have things like branches.
LOL I just went through some code the other day and removed all the disable structures and someone asked me why.  I said, "No need for dead code.  If you really want the code so badly, you can always go back and get it."
Bill
CLD
(Mid-Level minion.)
Message 12 of 12
(364 Views)
