Disable&gray a case of case structure
Hi!
I'm using 2 case structure to choose if I want a "Create Channel" or not. I don't know if it is the best way to do it but... It´s ok if I use this kind of control to choose the case? and... How can I disable and gray the items in the not selected case?
Thank's
TXL
(2,852 Views)
You can use the Diagram disable structure to disable the items instead of disabling the case structure (As it is not meant). Post your BD its easy to tell an appropriate way fotr your application.
24298i3B11DA667EC52B20
Smiley Wink
(2,843 Views)
Sorry I forgot to post it!! That I want is to use 2 or more cases, but when I am in the position "Case 2" I would like that the controls on the front panel to be grayed (or something like this...)
(2,827 Views)
Accepted by topic author TXL
Yes you can do it to any controls or indicator.. use the property node...
24316iCCA3F77B8B45820B
Smiley Wink
(2,818 Views)
It's ok,
thank you very much!!!
(2,800 Views)
