Disable autorun?
I have built the exe file of my project.
Every time I open it, application autoruns itself. I do not want it, I need to do some settings in front panel before running the application.
In File/VI Properties/Execution, the Run when opened is not checked.
How can I disable autorun?
(4,467 Views)
hi,
the answer is very simple. In application builder you have the menue
"VI Settings" - click on the top - level vi and then on "Edit Build Settings"
in bottom right corner. A new window appears where you can edit the
Target settings to "no" for "Run when opened" . Don't forget to click the
"change"-button.
cu
wha
(4,467 Views)
I think that the AB overrides the settings for VIs marked as "Top Level": they open and run when the app is launched. Modify your Top Level VI so that it does not enter the main code until the user press a button after the settings are done.
Jean-Pierre Drolet
Scientech R&D
LabVIEW, C'est LabVIEW
(4,467 Views)
