Disable event structure until in need
Hi All,
              Attached is the result page code. It suppose to act like a game where the picture appear at a random grid and show up. The user had to click on the correct 2D picture to level up after matching the same pattern
            The problem I face now is that when the state machine is not in the Result page and the user had click on the 2D picture already, it will memorise the click and when it come to the Result state, the result will be generated and go to the next level if correct or stop at the start if wrong
            Any solution for this?
Message 11 of 27
(1,794 Views)
From what I was seeing, I'm thinking the state machine might not be the architecture you want.  I'm thinking you could use a while loop with an event structure.  The event structure would then take care of all of your logic.  Keep some shift registeres to keep track of states.  This way, you can use the "Lock front panel until this event case completes".
Message 12 of 27
(1,783 Views)
Hi Crossrulz,
                  I dont understand your point 🙂
                  Can you elaborate. My state machine is not the full code as I am still figuring out the event structure. At the game state, I will process a random code generation to sequence through the state diagram. Now my problem is when the state is finished, it will alway got to the result state for the appropriate click. However, before going to the result state, when the mouse button is click, it will register the click already. So I would like to disable the event until the result state is called.
Message 13 of 27
(1,766 Views)
You would use one single event structure in the "Start" case, add "result" as a second condition to that same case. It will contain all possible events you need. (OK to start, mouse down, etc).
In the "mouse down" event cases use a case structure wired to the state that has an nearly empty default case, but does the appropriate state switching in the "result" case.
Message 14 of 27
(1,759 Views)
Here's a broken draft that shows some of these points. Most of the other code is missing, but it should give you some ideas.
Message 15 of 27
(1,755 Views)
Hi
Message 16 of 27
(1,735 Views)
Paradigm1999 wrote:
  1. Right-click the terminal...create reference.
  2. Simply look at my code. I create an array of references. The event terminal outputs the reference of the control that has been clicked. If you search the array of references for it, the resulting index will give you the control that fired the event. That's all you need. (make sure you arrange the array in the correct order to simplify the assignments).
Message 17 of 27
(1,731 Views)
You did already tried with cursor vi, with get busy.vi can disable click while completing the process.
Message 18 of 27
(1,725 Views)
Hi Mahu,
                 what you mean by cursor.vi and busy.vi? Where can I get these VI?
Message 19 of 27
(1,703 Views)
Hi Mahu,
             I saw the set busy.vi but it cause the cursor to be in busy icon. Ppl may misunderstood it as the VI is not ready and is still loading. Is there a way to disable the cursor without marking it looks busy?
Message 20 of 27
(1,697 Views)
