Disable special characters in Match Pattern function
I'm currently programming a parser but the parsed text sometimes contains special characters like "?"  for example
As a consequence, to match this expression I shoud force the "\" before this char.
Is there a way to simply disable the special characters in the Match Pattern.vi ? It'd avoid me to write a program to add "\" before any special char of my text...
Thank you in advance for your help.
 Bim
(4,754 Views)
You should try using Search/Split String instead.  It doesn't use any special format characters in the search string.  The only con is it doesn't have the match and rest of string separated.
(4,749 Views)
I don't see the problem with having these characters in the 'string' being searched by Match Pattern.  Are you wiring these into the 'regular expression' input?  Perhaps I'm misreading your explanation; could you post an example?
Jim
Jim
(4,727 Views)
If you use regular expression you don't have the choice to put "\" before any special character, it's the regular expression syntax.
Thanks to use NI forums.
(4,712 Views)
Would it work to use the "Search and Replace String"-function?
/Y
Qestit Systems
Certified-LabVIEW-Developer
(4,706 Views)
Finally I get a result by adding "\" on these characters : [\.\?\\\^\[\]\+\*\$]
Thank you for your help
(4,696 Views)
