Disable zoom out tool in graph palette
Quick question to see is it possible to disable only the zoom out function on the graph palette or limit how far the zoom out will go to?
I have not lost my mind, it's backed up on a disk somewhere
(3,391 Views)
I can think of catching the zoom event (scale range change) and forcing it back to the original values.
Jim
(3,387 Views)
Hi Jim
Thanks for the reply. This works for stopping a zoom out function but it also stops the zoom in function also
(3,379 Views)
A workaround could be, if you create your own Graph palette control, it can be done quickly with events and property nodes, and with the benefit you are flexible with options. Beside, hide the built-in Graph palette of your Graph.
(3,375 Views)
@PauldePaor wrote:
Hi Jim
Adding a little more complexity gives this:
Jim
(3,356 Views)
