Disabling image "zoomfactor" filtering
Thanks for persevering!
Luke
Luke_A_P
Message 11 of 14
(888 Views)
Hi Luke, I've been looking into this with James and we have just had word back from a member of the R&D team. Unfortunatly there is nothing we can do to change the behaviour you are seeing within LabVIEW. It is an OS function called by LabVIEW causing the problem and with the current release we can't change how the image is stretched. I will file a corrective action request so that this can be adressed in later versions of LabVIEW. Thanks for your patience and I appologise that we couldn't be of any more help. Regards, Tom
National Instruments UK & Ireland
Message 12 of 14
(853 Views)
Thomas, thanks for the info. Is it possible to say whether the filtering/not-filtering behaviour will be consistant if the same code is run on different PC hardware?
Luke
Luke_A_P
Message 13 of 14
(842 Views)
Hi Luke,
The hardwear shouldn't make a difference as the function is in the OS.
Tom
Message 14 of 14
(829 Views)
