Disabling the Cursor Legend not possible in LV2020 SP1?
Hi All,
I don't want my user to Add/Delete cursors using the Cursor Legend. How can I do this? There seeems no way to Disable the Cursor Legend, only the Plot Legend!
I use LV2020 SP1. In LV7.1 the behaviour of the cursor legend was way better then now..
No solutions for our SW:
  • Add transparent control over the cursor legend. As I still want to use the cursor legend for collapsing and operating on the cursor legend.
  • Make it invisible
Davy
(2,669 Views)
Hi Davy,
Check the CursorList property from time to time for the required number of cursors…
(2,661 Views)
I would prefer not a programmatic solution like polling constantly for amount of cursors.
I believe NI should have thought about disabling items in their new hardcoded (right-click) menu's.
In fact, I want to find a way to disable the Context Menu of the Cursor Legend. The questions is: Is there a way to do that?
(2,659 Views)
A slightly roundabout way to disable the context menu of the cursor legend...
Create a "Mouse down?" filter event for the graph and discard the event if the right mouse button was clicked on the cursor legend. I can't see an easy way to get the coordinates of the cursor legend, but you could perhaps size a button to the same size as the cursor legend, and hide it behind the cursor legend, and then get the coordinates of the button.
Something like this:
(2,589 Views)
Thanks for all the recommended solutions as they work fine for a single tool.
Unfortuantely we have like a huge list of 150+ tools (not speaking of their subtools), all converted from LV7 to LV2020 using graphs and changing all tools will require a lot of manual work which means we probably have to jump into scripting again to try to solve this.
(2,486 Views)
