Discrete Derivate when an input changes
Hi, i'm trying to make a discrete derivate. The dt depends on when the input changes and i need to hold the same value of derivate when the input is not changeing.
Right now im trying to derivate a sort of ramp.
The real signal will be a counter who increments when i see something with my webcam, so the dt can change between two counts.
I tried doing like this but doesn't work.
(3,698 Views)
I am trying to help you. However, i did not find the complete solution up to now.
Part of the solution is to figure out how to display non equal spaced data in the diagram.
I attached an example which does exactly this. I have to combine this with the pointwise derivation code, now. I'm very hopeful to present you the complete solution, soon.
(3,640 Views)
Accepted by topic author GianmarcoSbarra
(3,622 Views)
Thank you!
(3,604 Views)
