Disguised Windows task bar if executable is running.
Can you right click on the taskbar, select properties, then general tab, check auto hide option??
Message 11 of 13
(1,019 Views)
You can use the Window Appearance settings to make a VI full screen, but this will still allow the user, for example, to click Windows+D to show the desktop. If you want to really block all user rights, you should probably do it in windows.
___________________
Try to take over the world!
Message 12 of 13
(1,015 Views)
You can tighten it down a bit more withinin LabVIEW by:
  • Making the windows modal. It will be above the windows task bar even if the task bar is set to "always on top".
  • Don't allow resize and minimize, fit window to screen, hide all windows decorations.
  • Filter all key presses with an event structure.
  • etc...
    Message Edited by altenbach on 06-03-2005 09:18 AM
  • Message 13 of 13
    (1,010 Views)
