Displacement Power Factor of Non-Linear Current Waveform
How can i Find Displacement power Factor of Non-Linear Current Waveform & Sinosoidal Voltage Waveform & get displacement Power Factor value in Numeric Constant.
If you attach .vi File, it will be a great favour.
Regards:
Haimo
(3,894 Views)
I came across this similar forum:
http://forums.ni.com/t5/Multifunction-DAQ/How-to-get-power-readings-such-as-Power-amp-Displacement-P...
Have you looked into the Electrical Power Suite?
https://www.ni.com/en-us/shop/product/labview-electrical-power-toolkit.html
Michael Keane
(3,754 Views)
Actually In Electrical Power Suit (EPS) measures the power factor of linear loads...
in Nonlinear loads power factor is the product of Distortion power Factor and displacement power factor.
I want to find Distortion Power Factor.
if any on upload .vi file it be great pleasure.
thanks
(3,718 Views)
It looks like the distortion power factor depends on the total harmonic distortion, so perhaps you could use this VI to find THD and perform the equation from there:
https://www.ni.com/docs/en-US/bundle/labview-api-ref/page/vi-lib/measure/matone-llb/harmonic-distort...
Michael Keane
(3,693 Views)
From  THD i will find out Distortion Power Factor, that's right.
but the issue is i want to find Displacement Power Factor, that's the issue
(3,668 Views)
