Display 1d array to Pmod CLS LCD Using SPI
I have written an array which i want to display just the numerical contents in order on a Pmodcls LCD display using SPI. The array contains factors of a number. After the number is factored the array then goes into another loop which removes all of the zero and only leaves the results. Example 1 d array displays 0,1,2,0,4. after the zeros are removed i am left with a new array which displays 1,2,4. I want to display this information onto the LCD using SPI. Since the factored number can become larger then 4 i need all the numbers in the non zero array to be displayed as it changes. I have tried so many different ways and i am just drawing a blank
Thanks for any help.
(2,695 Views)
code please!
(2,656 Views)
