Display Images in sequence
Hi guys,
What will be the best way to display images in sequence.
I have a folder that contains about 100 small size images, and I would like to display it on the screen with fading mode. That is, the first image will be displayed, then fade away, the second image will follow and so on. This images will be displayed on my front panel .
The images are sequentially named. like pic01, pic02, pic03.
Thank you.
Message 1 of 12
(7,741 Views)
You can use an Picture Ring and can copy all the pictures to that ring one by one. See the example vi attached this may help in some way.
Regards
Aks
(Appreciate answers by giving KUDOS)
Hit the stars.............. sky is not the limit.
Message 2 of 12
(7,737 Views)
Thanks for the VI Akshath. Just one question, how do you add pictures to the ring picture, the option to export from clipboard is disable when I right click the control.
Message 3 of 12
(7,732 Views)
First you copy the picture to paint and paste there. From there again copy the picture and right click on the ring control the option will be enabled. if any problem reply me.
Regards
Aks
Message 4 of 12
(7,722 Views)
If the image folder will change from time to time, you may want to read the files and display the results in a picture indicator.
In the File palette use the List Folder function to get an array of file names.  Feed that array to a for loop which contains the  Read JPEG or Read PNG File.vi followed by the Draw Flattened Pixmap.vi.  If your pictures vary in size you can use property nodes to determine the sizes and zoom them to fit your display.
I have written a Slide Show VI which does all this.   I have not tried to implement fading.
Lynn
Message 5 of 12
(7,703 Views)
Lynn can I have a look at the file, what you have done is similar to what I am trying to do. I will develop it and add fading capability. my email is ade77@verizon.net
Message 6 of 12
(7,693 Views)
What version of LV are you using?
Lynn
Message 7 of 12
(7,688 Views)
I use Labview 8.5. I also have access to 8.2
Thank you.
Ade
Message 8 of 12
(7,670 Views)
Can you post the VI.
Regards
Aks
Message 9 of 12
(7,658 Views)
I will try to post a simplified version of it later today.
Lynn
Message 10 of 12
(7,627 Views)
