Display LabView panel as part of .Net window
Opposite to this statement:
http://forums.ni.com/ni/board/message?board.id=170&message.id=168857#M168857
what I would like to know is if I can display a LabView panel as part of a .Net window.
Basically the LabView panel should be some sort of an User Control in .Net.
Or maybe is it possible to run a LabView panel modal!?
I already created a LabView VI, where I set the panel to be modal, I put in into a DLL, but calling it from a .Net app is not behaving as modal.
Thank you,
Mihai PALADE
(2,830 Views)
Mihai,
It sounds like you are on the right track. The best way I know of doing this is to build the VI into a DLL and to call it from .NET, but you need to make sure that you specify "show front panel when called" from the VI Properties. The process of using LabVIEW front panels in .NET is outlined in this post. Hope this gets you pointed in the right direction!
Kind Regards,
E. Sulzer
(2,818 Views)
