Display Multi Port S-Parameter data
there are a lot of programs out to display 2 Port S-Parameter. But what I'm missing is a software that is able to plot Multi port S-parameter data. I would think of some kind of Matrix where you can just select any Port combination that you would like to be displayed by a matrix of boolean selectors. I guess Labview would be an ideal tool for implementing a method for displaying S11, S21, FEXT and NEXT.
Does anybody know if there is an exisisting VI that allows to plot multiport S-Parameter data ?
Thanks and regards
Hermann
(3,933 Views)
Hi Hermann,
I don´t exactly get what you mean, since the S-Matrix that you have measured already shows
the Portx-Porty-Relation when looking at Sxy or Syx. But sure, you can display the values of the
S-Matrix in any fashion with LabVIEW by creating a custom cluster-based control, for instance.
But as far as I can see, there is no "special" example-vi on the web.
regards
Marco Brauner NIG
(3,889 Views)
Hi Marco,
thanks for the Feedback.
Í understand, that everything is possible ... I just hoped, that I don't have to programm it on my own  ;-), as such a VI would be something many people could need.
There is a nice vi to display a TDMS file. I'm looking for something similar for S-parameters.
One Example: I do have two 10 Port S-Parameter sets from two different connector vendors and I would like to compare it. Not only displaying and comparing it, but also converting it from Single ended to Differential would be interesting.
But I guess as you mentioned, that there is no "special" example vi on the web I have to implement it on my own  😞
Regards
Hermann
(3,886 Views)
Hello Hermann,
you right I´m afraid. 😉
Marco
(3,879 Views)
