Display Options Locked
I want to change the Front Panel options to make it look better, but the change i make in the options doesn't do anything.
For example, I choose "Control style for new VI's -> System", I will still get default controls, even with new VI's.
If you know what is happening and can help me, thanks by advance.
(2,869 Views)
Accepted by topic author Julien.K
Hi Julien,
  • Existing VIs will not be changed when changing this specific option.
  • New VIs should use the "System" controls - as long as there are existing System controls for that specific control/indicator! (There are no charts/graphs, no VISA references, no colorboxes, …)
What else do you want to change?
(2,865 Views)
You already got a good answer, but please clarify what you mean by ""default controls" and how you "get" them?
For example if you right-click on a connector of a placed subVI and "create control/indicator", you typically get the same style as in the subVI, overriding your defaults.
Here I made a very simple subVI that had a modern scalar as input and output. Then I edited the subVI and replaced the control with a system numeric and the indicator with a modern chart.
If I place this subVI in a new VI and do a create/control/indicator, I get exactly what the subVI has. This is a great feature! I actually use it to my advantage, carefully selecting front panel elements in style and labeling for all my custom subVIs. 😄
(2,823 Views)
Personally, I would recommend not to use system controls as defaults. They inherit a lot of things from the OS theme and e.g. some buttons will look quite different if you compare the same front panel in windows 7 vs. windows 10 (no longer a really big problem since windows 7 is no longer supported as of LabVIEW 2021, but you get the idea). System controls also have very limited customization and a user that uses a really ugly windows theme will get an ugly front panel to match, no matter how good it looked during your development. Too many unpredictables!
Have a look at some of "frameless" silver controls as clean alternatives.
(2,821 Views)
Thank you all for your answers !
I never thought such a basic question would get so much.
I managed to set the "system" skin as default accidentally, so I guess everything is solved. 🙂
Enjour your Christmas Eve.
(2,798 Views)
