Display PDFs in LabVIEW without Adobe Reader?
I am trying to write a program to scrape some data from PDF's using Tabula, and I'd like to have an interface that lets users select a region of interest. To do this, I would like to display a PDF on a LabVIEW front panel and let the user drag a box to select it.*
I have tried adding an Adobe Reader ActiveX control to LV2018 32 bit using the examples floating around this forum, but it's giving me a very generic error ("There is a problem with Adobe Acrobat/Reader. If it is running, please exit and try again. (507:507)."). I've tried reinstalling it and searching for that error but can't seem to fix it.
Thus, I'd like to try using some other PDF viewer, but I can't seem to find one with either an ActiveX or .NET control. The Firefox built-in viewer works well, but I can't find a way to embed a Firefox window into LabVIEW either.
Any thoughts?
*Yes, I know that Tabula has an interface that lets a user select a region of the screen, but it requires a specific older version of Java RTE to do this, and the Java RTE requires a license for commercial use. Hence my recreating this in LabVIEW.
(3,862 Views)
I remember looking into this without any success.
Have you seen this
https://forums.ni.com/t5/LabVIEW/How-do-I-embedded-the-Chromium-Embedded-browser-in-LabVIEW/td-p/308...
If you can get that to work then you will have your viewer. Sorry I cannot offer any more help. If you do get it working please post the solution.
mcduff
(3,811 Views)
Have you seen this
mcduff
No I hadn't seen that one, thank you. I did try to get a Webkit .NET control going but couldn't figure out where to get the dll's being discussed on that thread, so that gives me some hope. Thanks for the tip.
(3,770 Views)
Not sure of your application, but I wanted to embed a pdf viewer so a manual could be look at within LabVIEW. I ended up going the HTML route and just using the >NET viewer from Windows.
You might want to search if there is a .NET assembly to access Edge, the new MS browser. If so, that should work as it is based on Chromium. (This would be a Windows only solution.)
When I have some time, I'll look into  this, https://docs.microsoft.com/en-us/microsoft-edge/webview2/
You have piqued my interest again.
mcduff
(3,759 Views)
That's basically what I was trying to do but couldn't figure out how to insert a Webview object as I didn't have it installed. The only source I could find with download instructions was for a package manager to install it into visual studio.
For the time being I just converted the PDF's into images to load up... it's not ideal but it worked for this application 🙂
(3,742 Views)
