Display TCP/IP connection ID indicator into front panel
Hello
How can I display TCP/IP connection ID indicator into front panel at runtime. So I can see the number as you can see then you place the probe on it.
Thank you.
Amit
(4,007 Views)
hello,
try this vi I attached, and let me know if it is work correctly.
(3,998 Views)
sorry, here is the vi
(3,996 Views)
Great, it works. I never deal with Variant before. Well I learn new method from you.
Thank you Amro
(3,990 Views)
I am pleased that I could help you Amit.
(3,988 Views)
Another option is to use the Type Cast primitive and cast the refnum to a number. That way you get the actual numeric value. It can be found in the Data Manipulation palette which is under the Advanced palette (before 8.0) or the Numeric palette (since 8.0).
___________________
Try to take over the world!
(3,966 Views)
