Display TDMS data on wavform graph
I have an existing program which can display TDMS file data on waveform. The file that I used has only one group. As I used the same vi for reading a multi group TDMS file, the waveform graph was not generated. Instead I got the error that Error 2525: LabVIEW:  TDMS file data could not be converted into the specified data type.
FYI I was able to read a particular channel from a particular group but as I read the timestamp column, I got the same error. Later, I am getting storage vi internal error.
How should I read such as file?
(2,583 Views)
Kindly upload your tdms file with the labview program.
CLD Using LabVIEW since 2013
(2,535 Views)
