Display Unicode Chars in text box
This seems like it should be simple enough, but apparently, I am dense...
I want to display a Unicode char in a text box based on its hex code input.  For instance, given x2190, I want to display a Left Arrow in a text box (x2190 is the code for left arrow).  I tried Flatten To String function then wiring the string to a text box with Force Unicode set, but that doesnt work.
Or is there a simpler way to get non-ascii chars like arrows and such to display?  Next stop is little bmps in a picture ring...ack
TIA
Bill F
(3,523 Views)
did you get a chance to see the document in the below link
http://decibel.ni.com/content/docs/DOC-10153
Anil Punnam
CLD
LV 2012, TestStand 4.2..........
(3,513 Views)
