Display Water Flowing
I am looking to create a pipeing system in a closed loop. I would like to be able to control valves and drains on the system. Is Labview a viable program for this program? It needs to display the water system and display the chang in water levels.
(2,992 Views)
Sure, LabVIEW is very likely to be the "best" choice for that kind of application.  Especially if you can afford the DSC Toolkit.
EDIT:  I'm assuming you meant "viable programming language" and not "viable program".  LabVIEW allows you to write code to do what you want.  It's not a valve control "program".
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
(2,991 Views)
Hi KevinP72,
As NIquist mentioned, LabVIEW is the best choice for this application, as it is a graphical programming language, you can program as you design your system and also, with the front panel you can see the actual data generated and acquired at the same time.
If you want more information about this, you can download a trial version of LabVIEW here, and you can have also the getting started with LabVIEW.
I hope this will help you in your project.
Regards
steve.bm
AE | NI
(2,953 Views)
