Display Word Document as read only in VI pannel
In a VI pannel I put an Active X container with the IE browser to display Word documents.
The document are displayed properly but I want not give the user the possibility to make changes while viewing.
Is there a solution to do so?
(The documents are read-only and can not be saved.)
(2,856 Views)
Why use an IE container to display Word documents? You can place a word document directly in the ActiveX container. This seems a better choice.
If you wish to totally block user-input, you can place a transparent picture control over the display of the Word document.
Another alternative would be to convert the word document to a PDF and show this in an AcviteX container.
Shane.
Using LV 6.1 and 8.2.1 on W2k (SP4) and WXP (SP2)
(2,856 Views)
Thanks for your support,
Rather this is not the solution I need.
When I place a Word document in a Active X container I am not able to change to another document programmatically (or is this al lack in my knowledge?)
Placing a transparent control over the Active X container with the IE does not work. The container is always "in front".
Changing all the documents into PDF is in our case not a practical solution.
So other ideas are very welcome.
Huub
(2,856 Views)
