Display a color image in front panel.
hi,
no worry, you didn't 😛
I believe George has what you wanna do. Try his solution, you will benefit from his creation 🙂
Cheers and good luck.
Ian F
Since LabVIEW 5.1... 7.1.1... 2009, 2010, 2014
依恩与LabVIEW
LVVILIB.blogspot.com
Message 11 of 19
(1,449 Views)
Hi George,
It seems to me that you have done lots of work on imaging. However, I could not view your vis since I have earlier version of Labview (6.02). How do you display different images in fixed size picture control?
Thanks again.
Hugh
Message 12 of 19
(1,449 Views)
To display different images in fixed size picture control,
you have to change to size of images to picture control
size, then you can use Ian's VI to display the image.
I'll send me a demo in 6.x
George Zou
http://gtoolbox.yeah.net
George Zou
Message 13 of 19
(1,449 Views)
Thank you very much, George. My LV version is 6.0.1. Do you need my email address?
Hugh
Message 14 of 19
(1,449 Views)
Hugh,
You can download Image Resize.vi from my web page:
http://www.geocities.com/gzou999/imgtool.htm
at bottom of the page.
George
George Zou
Message 15 of 19
(1,449 Views)
George,
Sorry for taking so long to response. I was away from office a few days and came back yesterday. I tried your ImageResize.vi and obtained a error message that says that a CIN could not be located. I understtod that this CIN is needed to run this VI.
Hugh
Message 16 of 19
(1,449 Views)
Be sure to try out the "daisy chain" function of the picture controls. You can keep adding features as necessary...just loop the PICTURE ins and outs and add what you need in layers. It's actually pretty cool.
Eric
Eric P. Nichols
P.O. Box 56235
North Pole, AK 99705
Message 17 of 19
(1,449 Views)
Hi Chutla,
Where can I find "Daisy Chain" function? I am new to color imaging and have not used Picture control yet.
Best regards.
Hugh
Message 18 of 19
(1,449 Views)
Silly Me!
It's not actually called a daisy chain....that's an old holdover from this geezers hardware days. What I mean is each picture control has a PICTURE input and output...you can loop the picture through as many nodes as you want, adding features one at a time. You can also resize the image at any step, but be sure you know how the "bounds" terminals work or you can get really strange results. When in doubt, wire the Bounds clusters together.
Eric
Eric P. Nichols
P.O. Box 56235
Message 19 of 19
(1,449 Views)
