Display and Graph time update
Dear friends
How a Display and Graph can update with a manual adjustable time control? Not using loop delay.
(3,300 Views)
Hi Alex,
you need to use a loop delay anyway when you want to update an indicator at a regular interval!
But it doesn't need to be the very same loop as your DAQ loop. You could use a parallel running loop with it's own timing…
(3,289 Views)
Ok.
My problem is exactly the parallel processing. I've used while loops in parallel and the data go by local variable. I think it isn't a good practice, maybe there is a better way avoiding local variable to pass the data.
(3,283 Views)
look in this forum for AE or FG (action engine or functional global)
(3,262 Views)
