hi,
Im very new to Labview. I would like to do a simple impact test using Labview.
The frequency range of my interest is only 0-200Hz. It is mean that I could like to capture the FRF for this frequency after I excite the system.
My question is how can I capture and display the results for FRF onyl after I excite the system.
My current condition is when I start the measurement there is some reading (may be is noise) showing in my graph indicator (setting at 0-200Hz).
When Im exciting the system using hammer, the curve of FRF is appear for a while and turn again into some noise reading (similar with before excitation).
How can I let my graph indicator show and stop at the FRF curve even after excitation?
Thanks alot^^
Regards
