Display captions in UTF-8 Chinese with Labview 2012
I've currently browsered over these sources
http://forums.ni.com/t5/LabVIEW/Reading-UTF-8-Files-in-Labview/m-p/792532/highlight/true#M361868
http://forums.ni.com/t5/LabVIEW/undocumented-function-quot-text-to-utf-8-quot/m-p/1034616#M460673
forums.ni.com/t5/LabVIEW-Idea-Exchange/Add-quot-Text-to-UTF-8-quot-and-quot-UTF-8-to-Text-quot-to-the/idi-p/1163291
http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Support-Unicode/idi-p/921449
Which provide little to no answer.
Basically I need to read a UTF-8 string from a file, and display it as a capation for Front Panel Objects (so that localization can change based on the users language). Is this possible in Labview? From what I've read so far this seems to be outside of LV's functionality.
(3,514 Views)
Attached is the VI I'm using in these tests.
This is why I see something like this:
\xC390 = 郂菃
On my US-Eng computer when I tell labview to convert to UTF-8
While the UTF-8  code points I’m referring too (U+00D0 or \xC390) should be Ð not 郂菃
(3,494 Views)
Hi Valarauca,
Unfortunately, LabVIEW has limited support for Unicode and it is not an officially supported feature. You may experience different results on different operating systems and different versions of LabVIEW
With that said, you can refer to this document for more information on Unicode in LabvIEW : https://decibel.ni.com/content/docs/DOC-10153.
(3,451 Views)
And for heaven's sake, be careful with this Unicode stuff.  It can screw up your LabVIEW setup - and all VIs that it touches - pretty royally if you're not careful.  (I think that starting with LabVIEW 2010 it's reversible, but still a pain to undo.)
That's probably why it was never officially incorporated into LabVIEW.
Bill
CLD
(Mid-Level minion.)
(3,415 Views)
This is what you want?
(3,372 Views)
