Display elapsed time?
This seems like it should be a simple matter. I want to display elapsed
time for the execution of the loop. I have two "Get date/time in seconds",
one outside the loop and one inside. In the loop, I subtract the outside
from the inside, and get elaspsed time for the loop. THis works fine-- my
saved data has the correct time values. However, I have an indicator wired
to this difference, and I have chosen time format to get a HH:MM:SS
display.
The problem is, it displays relative to GMT! So, instead of starting at
00:00:00, it starts at 19:00:00.
Is there a simple fix for this? I tried adding the appropriate number to
the value to get the display to zero at start, but this needs to be
changed every time daylight savings tim
e comes or goes.
thanks
(3,679 Views)
Hello!
Try to change "Regional settings" under "Control Panel" in Windows!
\PMN
"Christopher Hodge" wrote in message
news:91b1mr$bk3$1@news3.bu.edu...
> Hi,
> display.
> changed every time daylight savings time comes or goes.
> thanks
(3,679 Views)
"mller" wrote:
: Hello!
: Try to change "Regional settings" under "Control Panel" in Windows!
: \PMN
Don't you mean "Date/Time properties"? I looked into this after I saw your
reply, and it looks like it could work. But I didn't see any likely
options in "regional options". Did I miss something?
thanks,
Chris
(3,679 Views)
Did you choose Absolute time or Relative time. The relative
time takes a numeric count of seconds and displys it as elapsed.
No months, days, etc.
Greg McKaskle
(3,679 Views)
