Display fuzzy logic firering rule in front panel?
Hi all,
I only can display the firering rule no. (attached 1.gif red circule) in front panel.
How can I also display the firering rule no. detail infomation (attached 2.gif) in display panel?
Can I show the .fc file (generate in Fuzzy Logic Controller Design)detail infomation in display panel?
Fung
Message 1 of 11
(4,307 Views)
Hi all,
How can I also display the firering rule no. detail infomation (attached 2.gif) in front panel?
Can I show the .fc file (generate in Fuzzy Logic Controller Design)detail infomation in front panel?
Fung
Message 2 of 11
(4,306 Views)
Hi Fung,
What version of the Fuzzy Logic toolkit are you using and what is the function that you have shown in GIF 1?  It looks like the icons have changed and so I'm trying to find a 1:1 match between my version of the VI and yours.
Message 3 of 11
(4,274 Views)
Hi Kyle S,
I am using LabVIEW 8.5 with Fuzzy Logic toolkit. How to check the Fuzzy Logic toolkit?
I just add the additional output (firering rules" output ) of Fuzzy Controller.vi which shows its block diagram and one can see that it is made up of three  VI's one of which is called inferenz4.vi. Because I find the "firering rules" output on inferenz4.vi. (Following the post in this forums and title "Adding an additonal output node to a VI " at 06-14-2009 10:56 PM)
BRs
Fung
Message 4 of 11
(4,256 Views)
Fuzzy Logic VIs have been changed in 2009. Nevetheless, how are you generating the .FC file? Could you post an example?
Andy Chang
Message 5 of 11
(4,238 Views)
Hi all,
I generate .fc file in "Fuzzy Logic Controller Desgin". Just 2 input (error and change of error) and 1 output. And call it using "Load Fuzzy Controller.vi".
How can I show the firering rule (setup in "Fuzzy Logic Controller Desgin") in front panel?
BRs
Fung
Message 6 of 11
(4,227 Views)
Hi fung,
Could you post your .fc file?
Stephen Meserve
Message 7 of 11
(4,191 Views)
Stephen M,
Attached .fc file. Please help!
Fung
Message 8 of 11
(4,179 Views)
Hi fung,
There doesn't appear to be a built-in function to do this.  You would need to rely on using the Rules palette and the input values to see which rules were invoked.  I would encourage you to share this VI with the community after you built it by posting it on the community!  Thanks!
Stephen Meserve
Message 9 of 11
(4,142 Views)
Can LabView 2009 solve that problem?
Message 10 of 11
(4,113 Views)
