Display images from a SQL database
I want to display images from a SQL database. The images are in a table under a specific column and are stored as a link to the image. How would I display the images from the column in LabVIEW?
I'm using LabVIEW 2013 version 13 and SQL Server 2012
I have not lost my mind, it's backed up on a disk somewhere
(3,226 Views)
Hi PauldePaor,
I hope you are well.
Once you have pulled the data from the database into LabVIEW in a string form (or path), you can simply use the Read BMP File (Or jpg, png depending on the file type) VI.
More information can be found here:
http://digital.ni.com/public.nsf/allkb/02971A30F5D8FC6986256A0A004F11A0
Kind Regards,
__________________________
Aidan H
National Instruments UK & Ireland
(3,143 Views)
