Display in functions tools
I've imported drivers from Labwindows to LabVIEW tools panel, when now I open the tools panel and it display the folder of the drivers rather then display the icons as normal if I pressed on the pin to nail the tools panel, another way it displays as normal if I don't pin on the tools panel. Please see the attached file for more detail. Please let me know how to correct it.
(2,679 Views)
On the panel shown by your attachment word doc. Select the options button. Then select the Format to be Standard. Then press ok.
This should set it back to icons.
Regards
Ray Farmer
Regards
Ray Farmer
(2,679 Views)
