Display many hours in waveform graph
I'm testing a way to collect the output voltage from a power supply into a waveform graph and display the values in relation to absolute time over a few hours.
My problem is that I can only see the last few seconds in the graph. In addition, the absolute time on the right side of the x-axis is correct, but as the time is running, the left side of my x-axis show a time that is in the future. This should have been the time when the relating y-values had occured.
Do you have any ideas how to solve these challenges?
Attached you can find my VI.
(2,773 Views)
You could use an x-y graph like the attached example.
Andrew Alford
Production Test Engineering Technologist
Sustainable Energy Technologies
www.sustainableenergy.com
(2,751 Views)
Thank you very much. The XY-graph seems to be a much better graph to use in this case.
Now, things looks fine.
(2,734 Views)
