Display multi-WaveformGraph and only one was blinking
Hello everyone
please see the attached file TestFolder.zip
Test.vi is TopVI.
SubVI _Timewave.vi contain 20 subpanels , and each sublpabel insert the same VI(WaveformUnit.vi) for waveform display.
TopVI inset the _Timewave.vi with subpanel,  and waveform data is updated each second.
Only LeftTop waveformGraph has blinking problem. Please give us your advice.
(3,374 Views)
I have some VIs that aren't executable, maybe I am missing some typedefs?
(3,342 Views)
Hi gregoryj
Its LabVIEW compatible problem at user event.
My LabVIEW version is 2011, and I try to open this code with LabVIEW2015 , got the same problem too.
By the way I fixed miss VI (GPower clear error) in my new attached file and compile Labview2015 Version.
I had recorded the screen to GIF picture. please see the attached file Record.gif or the URL.
http://imgur.com/TIfqA7R
(3,316 Views)
