Display multiple spreadsheet on one XY Graph
Hello
How can i display multiple spreadseet on one XY Graph ?
i'm using this method for single file :
Message 1 of 9
(4,758 Views)
Accepted by topic author mori64
You can just use a FOR loop.  Autoindex on your array of files.  Inside the loop, you just read the file and process it as you already do.  Then you just append the array.  If you have LabVIEW 2013 or later, you can use the Concatinating Tunnel for the output array.
Message 2 of 9
(4,750 Views)
Hello  crossrulz
may i ask you show this for two files .
Message 3 of 9
(4,740 Views)
Don't know how to follow directions?
Message 4 of 9
(4,717 Views)
I like the use of subVI and non-functional snippet. Smiley Very Happy
Cheers
Message 5 of 9
(4,683 Views)
The OP already had that part figured out and I was too lazybusy to recreate it.  Besides, he just asked for an example.  No reason to do their job for them.
Message 6 of 9
(4,669 Views)
Yup, I figured as much.
Cheers
Message 7 of 9
(4,657 Views)
This is what i have done
it's really intresting that The color of the plots automatically got changed Smiley Happy
as you see here address is constant and number of file too.
now i'm working on user just select the folder and the code automatically display all file in the folder .
Message 8 of 9
(4,597 Views)
Hello
How can get the plot corresponding color ?
Message 9 of 9
(4,554 Views)
