Display of description for each block in Front Panel 8.5
I am talking about this screen.
Message 11 of 19
(1,532 Views)
Hi ganya,
the description is visible in the content help window, if your mouse hover over this control.
Mike
Message 12 of 19
(1,530 Views)
I am talking about this screen..
Message 13 of 19
(1,528 Views)
Hai ganya,
The Tip is nothing but a small message regarding that control. Whereas Description will give you the exact purpose of it. As mike said when u move ur mouse over that control it will be displayed in the context help(Enable it by pressing ctrl+H).
Mathan
Message 14 of 19
(1,525 Views)
In that screen whts the use of above block?
Message 15 of 19
(1,524 Views)
OK....Now i got ur points...Thank u Mike n Mathan....
Message 16 of 19
(1,520 Views)
Hi ganya,
did you read my previous post? It is only called "iteration ..." because your control has this name. The message you insert there will be shown in the content help if the mouse is over your control.
Mike
Message 17 of 19
(1,519 Views)
Hai ganya,
The above block is user-editable. Even u can give ur own description u want. If u didn't specify anything then appropriate comments will be included defult.
In the figure u attached u used a waveform graph. So by default it will give some description of it.
Mathan
Message 18 of 19
(1,516 Views)
Ya u r rite...thank u...
Message 19 of 19
(1,512 Views)
