Display of float values in Excel
Hello everybody,
i have a question to a faulty representation in my case.
When i use the constant for the upper and lower limit, excel present me a float number with 2 dots (U1) but i use only one dot.
Has anyone an idea whats wrong there,i can't find the reason for this.
Thx
(2,387 Views)
Hi DMego,
Excel can get confused when it receives several values all formatted as strings.
When you want to send DBL float values to Excel then you should send them as float - not as formatted string!
(Your problem is related to how Excel tries to out-smart the user in choosing the correct formatting for cells.)
I recommend to use a shift register for any reference-type wire crossing loops, like the Excel report reference/class wire…
(2,360 Views)
I always use the %s format specifier.
That way what ever number LabVIEW spits out is formatted into a string exactly the same.
No rounding or truncating decimals or loss of digits of precision.
Excel will still see them as a number
BTW: You can lose the Flat Sequence Structure in your VI and it will operate exactly the same.
THINK DATA FLOW!
=== Engineer Ambiguously ===
(2,341 Views)
