Well, a single LED alone will not show you what state it is in. It has only two states (On/Off), but your state machine has many.
You have a few possibilities:
- Just create an indicator on the enum wire in the loop. It will give ou the state in clear text.
- Create an indicator for any particular state, repeat if needed. (for example, the LED in the image wil light if state is in "exhaust four".
- Create a 12 element boolean array each corresponding to one state and turn them on as a function of state (using replace array subset)
The image below show a few possibilities. (And please try to wire left to right for clarity).
Message Edited by altenbach on 07-13-2006 03:45 PM
