Display quality problem
I've added a new W2k profile to my corporate PC.
After that quality of labview front panel gone down.
Its apply only to Labview. The rest of operating system and applications is OK.
I'm still under W2K 1280x1024x32bit graphic card resolution.
I've reinstalled LV to no effect.
Screencapture in attachment.
Any sugesstions ?
Regards.
Roman Nowakowski.
(3,277 Views)
You might try increasing the rights of the user. I have not experienced this problem or know why user rights should correct it but other problems are corrected this way.
Perhaps reinstalling the video driver could correct this.
If you have corrected the problem I would be interested in knowing what you did.
Thanks and good luck.
Randall
(3,277 Views)
I've administrator rights, and had reinstalled video driver - without result. The only way was to install Operating System again.
Regards.Romek.
(3,277 Views)
