Display signals in chart
I have one small doubt regarding charts.
How to implement second y-ax features for chart & also start and stop cursor to chart?
Thanks & Regards
Anitha.
Anitha
(3,562 Views)
You can right click on the chart and select properties.  Here you can set up your chart to have additional Y axis as well as add and name more cursors.  If you need to modify properties at runtime use a property node referencing the chart.
Paul
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
(3,536 Views)
    Thank you for your information.
Anitha
(3,521 Views)
Hi Paul
    I checked with chart peoperties there is no otipn to add cursors to chart.
For graph only have curson option.How to implement START & STOP cursor option to chart.
I want synchronize the sum o/p signal in between START & STOP cursor.
Thanks & Regards
Anitha
(3,482 Views)
Chart does not have cursor, only a graph can have cursor(s).
You can use the Graph instead of the Chart & achieve the property of multiple cursors, either statically or programmatically.
- Partha ( CLD until Oct 2027 🙂 )
(3,477 Views)
