Display waveform output (an indicator not the graph) on the front panel
Apologies if this question is obvious. Very new to labview so just getting the hang of it.
I want to display the output (some form of indicator showing the relevant values from the graph) from a waveform graph on the front panel. There is one listed in the Labview 6i examples under "Create a waveform". Not sure how to do it and kind find anything in the help files.
Help much appreciated.
(2,753 Views)
Just create an indicator off of the same wire that is feeding the waveform chart.
(2,746 Views)
Excellent. Thats it sorted. Thanks for taking the time to reply Jamie
(2,744 Views)
