Display your webvi application in ni-server
good evening  everyone
I had just finished prepared my  webvi application and i wanted to l uploaded as a dashboard  in  my  ni server  localhost . so if it is possible i would love to  have a tutorial  to know the step for doing it
thank you for your time
(2,459 Views)
Accepted by topic author Daliiheb14
Hi Daliiheb14,
The following GitHub repository contains an example for how to create a plugin for the NI Web Server dashboard: https://github.com/ni/systemlink-web-interface-template
The forum post Webvi_plugin template required changes to avoid duplicates also provides a description for steps involved in modifying the example to create a new plugin.
Milan
(2,434 Views)
thank you so much.
Iwill look for it then provide with a feedback.
(2,381 Views)
it work perfectly  thank you for your propostion
(2,374 Views)
