Displaying ActiveX PDF Locks Out String Control Input.
I have an application that displays a PDF, and has a "String Control" input for my user.  Once the PDF is DISPLAYED you can no longer type in the "String Control".  My ideal solution will be some code I can execute in the background, and not ask my user to "Click Five Directions" and "Look at a Blue Moon".Smiley Very Happy
I have found some things that allow "String Control" input after displaying a PDF:
1)  Press the "Tab" key and cycle back to the original "String Control".
2)  Display a "User Dialog" (the "OK" button) after displaying the PDF and it gives control back to the "String Control".
I made a simple VI for your review.  Please download and test.  I have asked NI support, however, they are stumped right now, and need to send this bug to "R&D".
Any advise is greatly appreciated.
Thank you,
Doug
I am using Labview 8.2.
(6,556 Views)
I cannot reproduce this (the string control is working correctly).
What version of acrobat reader are you using?
Have you tried multiple documents?
Wire an indicator to the i of the while loop. Is this indicator updating
after the document is loaded?
Wiebe.
(6,547 Views)
Adobe Reader 8.1.2
Yes, I have tried many PDF documents.
Yes, the "i" counter continues as the while loop executes...before, and after the PDF is displayed.
I sure would like to know what versions of Labview you are using, and Version of "Reader"/"Acrobat".
Doug
(6,542 Views)
Doug,
I can repeat your problem on my laptop (Vista32, LabVIEW 8.5, Adobe 8.1.2).
Work around attached.
George Zou
George Zou
(6,536 Views)
I will have to upgrade from LV 8.2 to LV 8.5 to see your report.  I have LV 8.5 but have been to lazy to install.  It seems everytime I upgrade all my custom VIs stop working.
Now I have a reason to upgrade.  I'll report back after I have tested in LV 8.5.
Doug
(6,533 Views)
Oops.  Sorry.
The workaround should work in 8.2 either.
I saved it to previous version (8.2).
George Zou
George Zou
(6,527 Views)
GEORGE ZOU!  OUTSTANDING!  IT WORKS!Smiley Very Happy
The key ingredient was "APP" "BRING TO FRONT".  Located on the block diagram --> Application Control --> INVOKE NODE will give an "APP", change it to "BRING TO FRONT".
Excellent work George!
Thank you very much!
Doug
(6,499 Views)
