Displaying Bitmap with ActiveX
I was trying to diplay Bitmaps, which I read from a oscilloscope. I am using a ActiveX container with the class _DlmgEdit (Wang Image Edit Control). This works just fine, but only once. When I read a new Bitmap from the scope and overwrite my temporary file from which I read the image, I always get the old picture. I have tried several things, but although the original file does not exist anymore, I can not read from a file with the same name, but new content. Hope someone can help.
Thanks in advance
(3,911 Views)
Is the saving and reading done from LV or externally? What I'm getting at is - is it possible you're not rereading the new data from the file? If this doesn't help, I suggest you post your code here.
___________________
Try to take over the world!
(3,907 Views)
I am reading the bitmap from the oscilloscope and write them to a temporary file via LV. I tried to display this file, but I found out that although I created a new file with the same name, it always displays the old one. Only restarting LV helps; then the updated image is shown. Using different names also helps. I solved this problem by giving a random file name and deleting this file after I have created an object from it. This is not an elegant solotion, but it works. Is there a possiblity of doing this more direct?
Message Edited by AWerner on 03-07-2005 09:14 AM
(3,904 Views)
I will suggest again that you post your code.
___________________
(3,897 Views)
why are you using active x just to display a bmp file why do you not use the picture control. Here is an example.
If this does not I would also suggest that you post your code.
Joe.
"NOTHING IS EVER EASY"
(3,890 Views)
