Displaying Case Structure Label by Default
HI All,
I am trying to enable the label for 'for loop' & 'case sturcture' by default. Currently to label them I am following the stepes Right click-> Visible Items -> Label.
Is there any way by which the labels are displyed by default as sson we drop the structre in the block diagram. Thanks a lot in advance
S.P.Prasaanth
(4,543 Views)
Check is this what you are looking for? Subdiagram labels visible by default—Displays the subdiagram labels for new structures on the block diagram: https://www.ni.com/docs/en-US/bundle/labview-api-ref/page/resource/dialog/preferencesdialog/preferen...
uday
(4,534 Views)
HI Uday,
Thanks for the post. But I am looking for a way to display the label of the case structure as soon as we draw it. Attached image for reference...
Prasaanth
(4,525 Views)
I am not aware of this in any options. You can do with scripting as below:
uday
(4,502 Views)
I also like using both labels and sub-diagram lavels for my case structures.  The label gives an overall description of the what's inside while the sub-diagram labels get more specific.
I just live with the fact that I have to manually show the label every time.
Bill
CLD
(Mid-Level minion.)
(4,484 Views)
