Displaying Entire History in the Graph
Is there any way I can display the entire history of experimental data in a Waveform chart?
I am trying to acquire the torque data over a period ,say, 1800 seconds (30 minutes), and would like to display the entire data in a graph while it is being acquired.
(2,707 Views)
right-click on your chart and select "chart history lenght...". Enter the desired number of points (default is 1024. Keep it reasonable, though). What is your data rate?
(2,706 Views)
There's also a property node for the chart history length, so you could set it programmatically.  However, realize that the bigger you make the chart history, the more memory it uses.
Brian B
Account Manager
(2,693 Views)
