Displaying Max & Mindata from multiple measurements
I’ve created a VI which measures and displays the max & min torque of a cycled part.
What I’d like to do is load more parts, test each one and have the max/min values show on an array, under each previous set of measurements.
Any advice is appreciated.
(2,451 Views)
You could use a FOR loop around your current code and just autoindex the max&min out of the loop, creating your array.  You will need to make sure your Max & Min PtByPt gets reset with each new part (reset if i = 0).
(2,424 Views)
