Displaying Previous Max Values and Min and Max Condensed Layout
Did you just attach exactly the same Vi that you posted earlier? What's the point?
(Sorry, cannot look at the VI on my current computer. If it is a different VI, you need to give it a new name!)
Message 11 of 13
(368 Views)
I have attached my current VI
Message 12 of 13
(364 Views)
As I said previously, your VI is still completely wrong. The shift register needs to be anchored on the outer loop. Currently you are creating new array with four identical elements with every iteration of the FOR loop. Complete insanity! Did you study my example?
You probably should start again with the learning resources and familiarize yourself with the magic and power of dataflow. Then work out your problem with a simple VI using simulated data until it works correctly. No need to carry out all that extra baggage of a gigantic VI for now.
Message 13 of 13
(350 Views)
