Displaying all Waveforms using Read Waveform from File
I need to save my waveform using custom file format. I was able to save the said waveform but when I read the waveform from the file it only displays the first cycle of the stored waveform and not the complete waveform that was stored during the run.
Also is there any way that I can save multiple files without letting the user type the file name
Like in Write to Measurement File multiple files are saved with date format as its title.
(2,955 Views)
Have you read the help for that VI?  It says that to read all the records you need to call the VI in a loop with the offset wired to the "i" terminal of the loop.
This is somewhat different from the way most other file read VIs or functions work, but the help is helpful.
Lynn
(2,941 Views)
