Displaying an Enum value and Item name when the Values are not sequential
I've been using some Enum controls and indictators successfully with some shared variables and modbus.
For example:
Item name Value
Off:                0
Startup        1
On                2
Enum setup works great, i dont need to lookup a cheat sheet to convert from the Item name to its Value, i just see the Item name in my control/indictor.
My new variables I'm trying to handle look like this:
Item name     Value
Off Code         0x201
Start Code      0x202
On Code         0x001
Any Ideas how i can display the value and the Item name on a front panel. ( for a control and an indicator)
For enums, it looks like the item Values have to go 0,1,2,3,4,5
(6,129 Views)
Under the Visible menu there's something called Digital Display (or something like that.  I don't have LabVIEW on this computer).  Is that what you are looking for?
Bill
CLD
(Mid-Level minion.)
(6,120 Views)
Hi Bill,
I already use the digital display.
The problem is that i cannot enter my own values in the enum properties, labview automatically selects 0,1,2,3,4,5
What if my values are 0x201 , 0x202 ?
James
(6,113 Views)
I can use a case structure ( see attached) but this is overkill. Surely there is a way to do this with an indicator/control without making labview for each variable name and value i want to display.
(6,108 Views)
Accepted by topic author jamesy777
I found the solution:
http://digital.ni.com/public.nsf/allkb/79BA4505AE8C755E86256FB2000140B0
use a text ring and unselect sequential tick box
(6,085 Views)
Sorry I misunderstood you.  Good to see that you found your solution on your own.  🙂
Bill
CLD
(Mid-Level minion.)
(5,835 Views)
