Displaying an Incorrect page in a tab control
I'm coming across a weird issue for the first time. I've got a typedef tab control, and when I open the VI, the contents of the first page are displayed in the control, even though the first page is not the active tab. I've attached an example VI. When test tab.vi is opened, you'll notice the String page is active, but the Boolean control is visible. This persists even when the VI is run. Switching pages makes the correct controls display. This only seems to happen when the tab control is a typedef, but I haven't done any thorough testing.
I've observed this on 8.20, which is the most recent version I have installed. I looked for, but didn't find, this issue in the 8.5 or 8.6 bug fix lists. Can anyone confirm that this is happening or let me know if it does not persist in more recent versions?
(4,642 Views)
I opened it in 8.5 and see the problem. However, once I operate the tab, go back to the string tab, make current values default, and save, things are OK next time I open it.
(4,629 Views)
Tab controls have given me similar fits as well. You need to preset your active tab page in an init state in your code with a local or property node.
PaulG.
Retired
(4,628 Views)
It is also good in 8.2.1 once I do the same.
(4,627 Views)
Twiddling the tabs, setting current value as default, and saving/reloading seems to fix the problem on 8.20 as well.
(4,620 Views)
Reported to NI. CAR #127705.
(4,557 Views)
