Displaying chart from one vi in another
Ok, here are the screen shots of the main VI and subvi
Message 11 of 21
(1,810 Views)
Ahh, my eyes, my eyes!!! Besides the easter egg diagram color scheme, there is really very little we can tell from a picture, especially is you have sequence structures stacked 10+ frames deep. What's up with all the coercion dots?
So it seems that the subVI is called one point at a time. All you need to do is assign a terminal to the chart and read it in the main IV.
Message 12 of 21
(1,785 Views)
I don't know what coercion dots are @.@ Sorry about the colors XD i got bored at one point >.> ... <.< ... if you notice, the icon for the main VI is a kitty +.+ ...
I tried assigning a terminal in the subvi to the chart. Do I insert the exast same chart in the main vs and connect the terminal from the subvi to it? When I did that the main vi first complained that it needs to be attached in every frame, then when I got to the last frame it suddently started complaining that it doesn't know which way the information is going 😞
Message 13 of 21
(1,780 Views)
Stop using stacked sequences! 😄
Message 14 of 21
(1,776 Views)
But ... it's the only way I know +.+  ...
Message 15 of 21
(1,773 Views)
Then you have to take Tutorials on LabVIEW basics. 🙂
Message 16 of 21
(1,766 Views)
 Well, you clearly have some serious dataflow problems, mostly caused by overuse of stacked sequences and poor understanding of dataflow in general.
A stacked sequence really does very little ... Where did you learn LabVIEW? Maybe you should start with a few tutorials if this is giving you problems.
Feel free to attach your actual code so we can give less general comments..
Message 17 of 21
(1,763 Views)
I never learned LabView 😞
A few weeks ago, my adviser said "Here, make this work...", so that's what I'm trying to do >.<
So you don't know of a quick simple way to get the chart to show up without rewriting the entire program? Cat Sad
Here are the actual programs just in case. (I inherited the subvis from the last student, so it's not my fault if they're horrendous. >.> I just edited them a bit +.+)
Message 18 of 21
(1,755 Views)
Your subVIs dont seem to have any charts.
Your main Vi does not have any charts either, just an xy graph.
Your entire code architecture seems inside-out. How are you running this? The main VI does not even have a while loop!
Message 19 of 21
(1,738 Views)
isn't that blue thing a chart/plot/graph? %\ ... gah ... that's where the points appeared ... so i just assumed +.+ ... oh gawd, I'm so confused right now  ...
The main VI takes as input the number of increments and feeds it into the subvis which have while loops >.>
Message 20 of 21
(1,729 Views)
